the 200-4r cross member works with th400 if you use the 200-4r trans mount (slot the holes out) ..
but
you have a 79 and cant use the 200-4r cross member unless you weld the mount pad to the frame rail under the driverseat area
earlier frames built before the overdrive dont have the frame pad
