Jan 19, 2007 #1 S sprayed65 Member Joined Nov 26, 2002 Messages 85 What are you guys doing about the modulator valve? Running a vacuum line, running a line with a one way check valve or not running a line to it? Any other scenarios Im overlooking? Ryan
Jan 19, 2007 #2 N norbs Classic fast, XFI, SPortsman & MS3 programming Joined May 25, 2001 Messages 6,212 YEs, you shouldn't be using a vacuum modulator on a turbo car but a mechanical modulator. THe vendors on this site can set you up with one.
Jan 19, 2007 #3 O Otto J Well-Known Member Joined May 31, 2001 Messages 10,546 If you run a manual valvebody,Or a transbrake valve body, A modulator is not required. It is only required if you want automatic shifting
