TH400 or 2004R?
my1stgn
As fas as times in the 1/4, how far could a 2004R tranny take you? Im looking at buidling the tranny in my car and I want to know if it would be just a waste of money to spend it on the 2004R. And any special mods to change over to a TH400 or is it just a direct bolt on? Any other tranny's to consider? The car isnt "real" fast right now but I dont feel like breaking anytime soon so I decided Id better build the tranny first since the engine is pretty solid..... do far....
if you get a WELL built 200r4 you will be able to hit 10's.. i had to many problems with mine, so i went with the 400. i also wanted to run a trans brake and it's a lttle bit safer on a 400.
Mike Kurtz has gone high 9's with a 200.... easy mid low 10's with a 200.. properly built of course..
I chose the TH400 because I didn't feel like spending $2k-$3k on a marginally capable 200R4 trans. Yes they are going in the 9's, but I don't have the budget to support a 9-second 200R4.
I can put a $800 TH400 in my car that will last me several years. The extra gear just isn't worth the difference in price in my opinion.
If I planned nothing more than a 12-sec street cruiser, then the 200R4 would have stayed in the car. I plan to eventually put mine in the 9's, so it only made sense to do the conversion right off the bat. No sense dumping money into a trans that would eventually need to come out anyway.
I looked at it like this...
Would I consider putting a 200R4 behind a 454 BBC with Nitrous ? Not in a million years.... So why would I put one behind a turbo V-6 that can make the same power ?
I just got done converting mine over... Just waiting for the driveshaft to get built.
It wasn't nearly as bad as I expected. The factory mount can be used if the holes are widened/slotted for the wider TH400 mounting pad. I had to relocate the shifter cable bracket on the pan rail, and fabricate a new pattern in the factory shift gate to accomodate the reverse pattern.
All in all, it was a pretty straightforward swap.
