- Jun 6, 2001
Changing to TH400 and after searching old posts still have a few questions.
- Does someone have a pic of their aftermarket shift linkage on the side of the trans they could post?
- Can the column/steering wheel lock linkage be retained with the TH400, if not, what is the "proper" way to disable it with zero risk of it engaging?
- Link for the check cooler line pressure and the best method to lower it to the desired 40psi?
- Does FAST need the speedo signal like the factory ECM? I can calibrate my speedo with whatever speedo gear is in the trans but wondering if I need the correct one for an accurate mph input into FAST. If I do need to change it, what is the part# for the speedo gear I should install?
- Will the TCI scatter shield interfere with the trans tunnel or is there plenty of room?
- ARP bellhousing-to-engine block bolt kit part#?
Mike
Mike
