TURBOELKY
- Jun 27, 2005
I got another distributor, put it in and its doing the same crap. The car fires right up, but has a miss to it, and will not idle. I know know its not the distributor, nor was it the original one. The only other thing that would cause these symptoms: wont idle, sounds like its missing a little, sounds like there is an exhaust leak,: maybe the carburator gasket? I had an old one sitting around, it was kind of hard, maybe it did'nt seal good?
I removed the carb., will pick up a new carb. gasket tomorrow and try that. Other than that, i'm confused. I know the distributor is in correct, all the wires are correct, its getting plenty gas, and I did'nt have any left over bolts after the manifold gasket replacement
except one BIG one
this thing is about to be 87'd real quick in a minute!!
