- Aug 1, 2003
winter is here at northeast and track will be closed till april so i figured i would post a slip from the last passes that i made in the 86 thanksgiving weekend buick vs ford
sat 11-25-2012 Atco raceway
heres the times as the car ran from 1st pass at 11AM to to 7th pass at 230pm
1st run left car as it was set at etown but had made some slight suspension tweaks
MSBC-1 electronic boost set at 8psi launch and 3800 bailey 2- step on Tbrake (TH400RMVB) , 24.5 psi all other boost stages
1.523 4.160 6.383 110.23 8.313 9.960 136.81
that was good lets try again... no changes
1.529 4.163 6.389 110.04 8.325 9.974 136.79
thats consistent enough to win most brackets
hook was good so lets try for little more off the tree
added 2 psi to launch boost (now at 9.5 psi and set 2- step at 4000 rpm )
1.464 4.078 6.296 110.26 8.229 9.876 136.91
added 1 psi to 1st boost stage (now 25.5psi for 2 sec and then 24.5 to top) and set 2-step to 4100 rpm
1.448 4.042 6.251 110.73 8.179 9.827 136.79
elimination round dialed 10.0 (thats all i could dial having just a roll bar) and hit a -.007 light so i stayed on it ..
1.454 4.078 6.298 110.33 8.230 9.877 136.80
went into test and tune lanes ...upped the launch 1 psi (now 10.5psi) added 1 psi to 2nd boost stage and moved 2-step to 4200
blew tires off !! track is getting cooler and air is getting better
1.863 4.532 6.752 110.50 8.678 10.320 137.23
i like the mph. debated packing it up and going home since it looked like i wouldnt get another pass before they finished the day ...well decided to sit in lanes and see if i could get one last try, didn't want to waste last run of the day spinning so launch back down 1 psi ( 9.5 psi) set 2-step back to 4100, upped 1-2 stages 1 psi (now 26.5 psi for 6sec and 25.5 top half of track ) ,
1.463 4.055 6.259 110.97 8.178 9.815 137.68
93 octane pump gas and razor alky dual nozzle meth injection
