It is amazing how an engine build turns into other things. So far suspension work, rusted out fuel lines, steering column issues and now rusted out brake lines. Had to disturb the brake lines while replacing the fuel line and of course it started leaking.
So I moved along to firing up the engine for the initial time after the rebuild. I noticed no scanmaster input and SES light on dash but it would crank. So I started it and it ran. Found the scanmaster issue to be a bad ground, then I see a light deep in the dash that is on (remember the column is in pieces hanging down) this must be the SES light that was not put back into the socket. I will fish that out later.
Engine runs good, got all the air out of the coolant system. Oil psi looked good, no strange noises. Top of ATF, at this point I am happy. Until I see oil on the floor. So I am like WTF. Take a peak and see the oil pump appears to be leaking. It is a Weber blueprinted preassembled front cover. I decided to put that off since I can handle that one way or the other till Sunday.
Off to tackel the steering column. Customer put in a new lock cylinder. Now it wont turn. He took it down trying to R&R the ign switch. I was starting the car using just the switch at this point. The rod from the column that's actuated by the cylinder is jambed. So major column surgery commences. Got it all the way down and the rod is in a severe bind. Fix that all up, put the IGN switch and hi beam switch on the column and bolted it all up. Car will start with rod now....
![Smile :) :)](https://cdn.jsdelivr.net/joypixels/assets/8.0/png/unicode/64/1f642.png)
....put the till mechanism and pins back in. Start messing with lock cyl and sometime it works and sometimes it does not...DAMN IT! I tossed in the towel for the day back at it tomorrow.
