Purchased and installed a Zimmerman built 237 109. Install has been ongoing for several months, While waiting for a few small items I decided to purchase Erics TT SD Chip. Setup went pretty straightforward. First couple of drives showed the fuel was too rich down low, Took it out for a short run around the block while recording the PL file. Things looking good then suddenly,,,nothin,,,no power. Car was running fine about an hour prior. Turned on the side road and slowly rolled into the throttle,,,was expecting to pull hard, It did lay me back but somewhere into this short burst the car :hiccup: no power, drifed to the side of the road. Car would turn over just fine...fuel pressure is there, Spark looks very orange or near red. Checked the crank sensor and it's still the same unit I replace about 2 months ago, During the drive the car was responding to throttle command very well. Pushed the throttle a little more and the car just died, Checked the powerlogger file from the run and saw the annomoly as it happend...then everything went dead, New plugs, wires, all check out...I ohmed the coil packs and they seem fine. Went back to the codes tab and there it was Code 42. leaning towards needing a new module? Any input would be greatly appreciated.
