Straight from Comp Cams website, interesting reading, I learned something new today....How to measure pushrods...
Measuring the length of a pushrod is really rather simple, but it can be confusing at times. The most important thing to remember is that different manufacturers measure pushrods differently. So not all pushrods of a stated length will measure exactly the same. The three most common pushrod measurements are shown in Diagram B on the next page.
Theoretical Length: This assumes that the pushrod has no oil hole in the end of it. Therefore, the radius at either end is complete, which lengthens the pushrod approximately .017" in the case of a 5/16" pushrod with .100" diameter oil holes, minimally chamfered.
Actual Length: This is what you would measure if you had a set of calipers large enough to measure over the oil holes at each end of the pushrod. This is the measurement that most people can relate to. Unfortunately, this measurement is affected not only by the diameter of the oil holes, but also by the entrance chamfer for each oil hole.
Gauge Length: Although the most difficult to measure (it requires a special length checking gauge part #4997), this measurement is the most reliable. This is because the oil holes and their chamfers are eliminated from the measurement. The only problem is that not all companies use the same gauge diameter. COMP Cams® uses a .140" gauge diameter. All of the Magnum and Hi-Tech custom length pushrods listed on pages 270-275 of this catalog are measured using this technique. See Diagram B on the following page.
So since I don't have the special length checking tool, but I do have a dial caliper that is long enough to check the entire pushrod, let's use theoretical length. In my case as I stated above in my first post, if you use actual length, which is not perfered, I had actual lengths between 8.234 and 8.246, but if we add the .017 as stated above to get theoretical length, we now have lengths of 8.241 and 8.253, and my pushrods are supposed to be 8.225?....could this be another reason why the comp cams roller setups are noisy because valve preload is not set properly?
Looking above, we have between .016 and .028 differences in length just in the pushrods from theoretical measurement to stated measurement on the pushrod. Now if you are trying to achieve .035 valve preload, you could actually be tighter than what you thought. Could this be a reason for collasped lifters?
