GNONYX
- Oct 16, 2009
Hi All,
OK everyone here is the question; Buick build a great GN muscle car, and we all know the engineering department has used quality parts and also cheap materials for parts. My question is this; the thermostat housing is made of thin steel material, and also the intake water pump nipple is made of steel. Is there a problem in using both parts made of Aluminum or Stainless Steel?
Did the engineering department knew something of chemical reaction if all is made of same material?
I'm in the process of replacing my GN thermostat housing, and I was wondering if I decide to use Aluminum housing will this material seize with the intake which is also made of Aluminum. Hmmmmm
