My GN is due for emmisions in June.....never had a problem before. The only thing that has changed is I have recently installed a power plate (it is drilled), 50 lb injectors and a turbotweak chip for the 50's.
Eric states clearly that it is NOT an emissions chip. I still have the stock chip but i'm not sure if the car will even run with it with the 50's, so should I just bolt on the cat and give it a try?
Chris
Chris
