This is sad-Open at your own risk!
Sucks about as much as this...
Do you have these in High Res.
I have a Carnage file I look at from time to time to keep the silly ideas from rising to the surface :p
Good luck with the repair. that is the beauty thing about aluminum.
Nope... it's Scrap aluminum....:mad:
Don't think so, we plan to fix it.:)
Will ship it to a place that specializes in alum block repair and has repaired other TA blocks that were damaged.
If this, or the other TA blocks, had been cast iron, they would now be boat anchors, and not ever see under the hood of a GN again.:biggrin:
Looks familiar, I got 5 cyliners worth of a cam, a shattered piston, and parts of the block from Bobby Petersons 8 second T. Spinning to 8K and going lean can do bad things to a motor.
especially when you add the 30+ psi of boost factor :eek:
Smacked
That GN can be fixed put into the right hands it would look like new again. Top notch body men could do wonders...
