THM-350C and 3.42's......(no posi)..
Freddie's Buick
Hell No! I'm not a junior
O.K.
I've read that this maybe too steep without overdrive...
Is it? Or can the 350 handle these gears?
What are the positive or negative results? :confused:
I dont have the th350C but i have a non lock up th350 in my car. i noticed no gas milage differance on the freeway if I drive the speed limit (70) car turns about 2,800-3,000 with a 28" tall tire.
Sleeper1987 said:
.....i have a non lock up th350 in my car. i noticed no gas milage differance on the freeway if I drive the speed limit (70) car turns about 2,800-3,000 with a 28" tall tire.
What rear gear ratio you have?
Based on calculated info here's what I come up with:
I need a lot of help in this area....I am relativley dumb in this dept.
Tires: 235/60R15=26.10 diameter
Rear Axle in the near future=3.42
Using a calculator, at 75-MPH the RPM's I'm getting are 3,305.
As it stands right now with a 2.41 rear axle I'm getting 2,329.
Duh....does this mean I'll be wasting more gas?
And If I am, at the very least will I gain some performance?
__________________
