I just installed a newly rebuilt THM200-4R into my '81 Regal, replacing a tired THM200C. After doing a gentle 500 mile break-in & then fluid & filter change, I took it out & gave a hard run to test it out. I noticed a couple of issues that I want to correct. First, I'm getting a 1-2 shift even when holding the shift lever in 1st manually, This shift occurs early @ 4000 RPM @ WOT. I have noticed that if I only use 2/3- 3/4 throttle, (not WOT) it will stay in 1st past 5000+ RPM & not shift until I move the shift lever into 2nd
I'm also getting an early 1-2 shift in "D", about 4000 RPM @ WOT. I've got the TV cable properly adjusted. The shifts are quick & firm, but too early. I thought I should also mention that I did a rear end swap from a 2:41 to a 3:73 just prior the the tranny swap.
Any input here would be greatly appreciated.
