Those of you running front mount intercoolers
"Turbo-T"
V6 on steroids
1. Can you run the A/C condensor in the stock location with a front mount IC?
2. If yes, is the A/C condensor still effective at cooling down the gaseous refrigerant with the front mount IC in place? Or does the IC shed it's heat to the condensor and make it not be as efficient?
Thanks.
The only time that there's going to be significant heat coming off the intercooler is when you are making a full throttle pass and making good amounts of boost, otherwise the turbo isn't making enough heat to matter at highway speeds.
