What the heck did you do with the power steering pressure hose? Since the stock pump gets turned on its side with the new bracket setup, now I have to make up a new pressure line. Keep in mind, I got a new stock replacement pump, and they don't come with a new hard line attached to it. Does anyone know the fitting size and type of fitting that goes in the pressure port of the pump? A 22 mm socket fits perfect on it. I was thinking about doing something like a Jegs Push-Loc hose with -6 AN adapter fittings. I would also need to know what the fitting size I would need for the steering gear pressure port (it looks slightly bigger than what is on the pump). Thanks a million if you can help. This is the last thing holding me up!
			 So will the stock hard line work on the pump? If so I need one!!!
