thoughts on what i should ask if i sell my 87 gn
bttwracing86T
YOU CAN'T HANDLE THE 6!
87 WE4
.020 block, dual row timing chain, ported factory heads and intake, RJC power plate, comp 210/215 cam, morel rollers, pac beehive springs, harland sharp 1.55 roller rockers,new front cover, new oil pump, new water pump, dave husek built transmission and 3021 9.5 converter, power logger, scan master, Turbo tweak 6.1 chip, lc1 wideband, lt1 maf, translator,racetronix 340lph, racetronix hotwire,80# injectors,6 return fuel line,acufab regulator, Precision 6266 turbo, 25psi boost,alky single nozzle,cas v4 slic, 3" downpipe, cutout, single 3" pypes race pro, 3 row aluminum race radiator, trans cooler,AC heat radio delete, south side machine lift arms, Koni adjustables,ta performance rear diff girdle,rear seat x brace, 275/60/15 mt drag radials. body is ok some rust rear drivers quarter needs patched and a few other spots needs paint all over.
what kinda price do ysll think i can get or ask
10K ballpark needing paint. depending on condition of interior. Pics would help
When, and only when, you decide what you want for your car, then post it in the cars for sale section.;) Please read the rules for the section.:p
id say probaly closer to 8. depending how bad the rust bubbles and how bad paint is. i purchased my 87 astro roof gn w a repaint for 11 or 11.5 car needed nothing at all. had 100k miles wpuld never know.
yikes yeah i wont sell that for sure no track times yet but 10.5 capable car it would take atleast 15k to step away from it
car is avatar
