I am adding a TA 49 and Blue Top injectors to my 1986 gn.I have already run a low 12 on my previous set up with a Thrasher 100 octane chip.I had one escape frame but no knock retard so I was on the edge.My mods are listed on my signature.It looks like for a Thrasher chip I have two choices for my car,a 92 octane or 97 octane chip.The 108 chips would be too much as I never run race fuel.If I am righ the 97 octane is kind of an experimental chip.Has anyone ever run it with success.I also understand that even though a Thrasher chip is not specifically burned for a TA 49 it will work with a TA 49.Am I right?Also I know a Thrasher is not set up for alcohol injection but the Thrasher 100 run great with it.I had to keep the pump speed at 4 until I hit 60 mph and then turn it up to 7 1/2.If I did not do this I was rich on the bottom end.If any of you have run these chips with a similar combination what kind of times did you run.One other note,since Joe Lubrant quit working at PTE I do not think he burns chips anymore.I emailed him two weeks ago and he never responded.The reason I upgraded the turbo and injectors is not necessarily to go faaster,I would like to run mid 12's or slightly faster with less boost than I was previously running.Bruce
