I installed 92 Thrasher chip on my stock GN. After warm up, idle was running rough at 1000 RPM and appeared to stall while stop in traffic. Any suggestion on how to make it run smoother?
You don't have a catalytic converter on the car do you? If so, there is your problem. If not, what is your MAF reading at idle with the Thrasher chip?
Originally posted by tech69 I installed 92 Thrasher chip on my stock GN. After warm up, idle was running rough at 1000 RPM and appeared to stall while stop in traffic. Any suggestion on how to make it run smoother?
Thanks guys for the quick responses. I decided to remove it after one day of trying. Too much humbug. I will reinstall when one of you guys is around to assist me.
