Thrasher & Grainger Valve ???
KWIKR 1
Is it best to run a Thrasher off of the stock wastegate solenoid or can it be used with a grainger valve type boost control without any problems ? thanks for any help .
If you continue to use the stock solenoid, you get the additional benefit if all-gear specific boost ramp control.
that's what i needed . I remembered something to that effect about the Thrasher .just wanted to check .thanks !!!!!!
