- May 28, 2001
When you do a volt drop, have the engine running.
W/engine running: Pos side test, - probe on alt stud, + probe on batt +
@ 40 A charge rate, drop should be <.4v. @ 100 A rate, < .8V. A clamp on amp meter is a good method to test the amp rate.
Grnd side, - probe on alt case, + on engine, or over to the - batt post. Should be <.5V.
Other items:
Belt slip.
Tensioner took a dump, allowing above.
Belt stretched, or wrong length.
Charge wire corroded at/under the connection insulation.
Other items:
Belt slip.
