87 national
- Mar 31, 2010
SignUp Now!its probably part throttle surge. Post up some logs and we can start to try to tune it out.
What are the boost control settings in the Pro,
What are the response settings in the Pro?
Bob
i will look later how it is wired but will i hurt anything to run the car without a wastegate solenoid or boost control because i dont have wastegate solenoid and now i wont have boost control all i will have is my waste gatewith those settings the boost control is not activated until 2.4v TPS.
Your surge is happening at throttle angles less than 2.4v, right?
how is the solenoid wired?
try running a hose from the turbo to the wastegate with no solenoid.
then, see if the surge is any different, and also see what the boost is with no solenoid.
Bob
