im putting together a spare 109 i have had for awhile. its stock bottom end the only machine work done was a puff hone and polished the crank. now after starting to assemble the bottom end, i noticed that the crank is binding on the thrust bearing. one side has .005 and the other side is touching the crank. could this be caused by the arp main studs? this is the first motor im assembling myself and any advice would be very helpful.
