I've been doing a lot of stainless lately and the purge block is to flood the back side of the weld with argon.... also the copper helps pull the heat out of thin stainless. I will end up tig brazing a couple of tubes to the copper purge block with silicon bronze.
Oh gotcha. I was going to make a copper block with a handle to prevent blowing through my thin floor pans when I welded them in. I didn't bother because I would have needed another Persian to hold it under the car while I was welding from the top. Very cool idea good luck.
I bought this solid piece for back up on long thin stainless edges. It measures 8 x 26 x 1/2 and I'm ashamed to say what it cost...now I know why crack heads will steal your out side AC unit.
Burning through to the copper will look bad on the underside of those floor pans. Just take your time and trigger it in. A nice and tight joint always helps.
