Daniel Jost
Squirtin six
- Oct 11, 2003
Well after a year long engine combo swap I finally got my car together and running this weekend. After starting it up and letting it run a little bit to top off the engine fluids and check the trans fluid and all the fun stuff you do after an engine build I got in to take it for a run to see how everything worked. When I put the car into gear F/R it now makes a whining noise which I have heard before pretty typical of a stator/sprag issue since it goes away when moving and not "Stalling" the vert.
I have an Art Carr 9-11 3100 L/U with the billet front cover in it now and talked to them about rebuilding it for $225, I also have looked at the RevMax converters as we have one in a Nitrous LSx swap car (4L80E) and have been very pleased and they are a very reasonable price. One for my setup would be around $500.
I am wondering if I should take the opportunity now to go with a higher stall? I was thinking 3400 L/U, I am spooling a older Turbonetics T-66. Is this to big of a converter? I drive this car 100% street use and frequently road trip it. Is the art car going to be good enough for high 10 second trans brake passes if I have it rebuilt?
Thanks, Dan
Thanks, Dan
