I currently run 4* more timing in lower gears (25*) than I do in third (21*) but i run the same amount of boost (27#) in all gears. I use 93 + meth for fuel with 10.7 - 10.9 afr. From your experiences, is this a good use of timing/boost or should I be trying some other combination? Would I be able to 60' better if I lowered the boost off the line?
