turbo39151
anycoloraslongasitsblack
- Nov 7, 2002
I decided that I'd get a little work done today. Mostly planned on cleaning everything and checking a fgew things here and there...
Dropped the oil pan since I was gonna do the rear main. Turns out I forgot that I had already done it.:redface:
Then, I removed the front cover since I was gonna swap to a double roller I had sitting on the bench. To my surprise it already had a double with a tensioner. With the tensioner the chain looked good and tight. With the tensioner off the chain was very loose. I checked the tensioner. It looks fine, not all chewed up. However, the upper sprocket had nylon teeth and I figured that this might eventually be an issue so I figured that I'd use my new chain...
Issue number 1: new chain fits nice but sprocket holes don't line up AND the new one is super heavy compared to the older one with the nylon teeth. The new brand is SA gear part number 78129 (Here's the link: http://southwestracingspecialties.com/product.cfm?InvKey=11662 )... And the new chain is heavier and slightly thicker than the older one. The chain is new but was purchased from another board member a few years ago... Not sure why doesn't fit...
Should I just reuse the old chain? Or pop for a new one??
Then there's the front cover... It was filthy so it's gonna get a hot tank bath, new seals and maybe a little port work. My question has to do with the cam button. The original plastic one was pressed into the front cover. I actually had to force it out of the divit it had created...
I was going to gring it flat but want to be sure that there's nothing else to look for or do.
Finally, while I was under the engine, I grabbed the ends of the piston rods and checked for movement. The fronts and rears are tight with no movement. The middle two have the slightest movement. Is this a problem? I'm not an expert so I do not know what I'm supposed to expect there.
I'm wondering if I this is the early sign of a worn bearing...
