- Nov 24, 2001
That bell piece is the oil slinger, it goes on after you install the timing set, small side first so it looks like it gets bigger toward you, then install the timing cover.  It goes in before you install the timing cover.
Did you line the timing marks up straight up before you removed the chain??????????
What i do to make sure the chain isnt off one tooth is...
Find top dead center on #1, thats the drivers side front, turn the motor over till air comes out #1 piston...DO THIS WITH THE CHAIN ON!
You dont want to turn the motor over without the chain or you will bend pushrods.
Make sure your timing marks are lined straight up best as possible, then temorarily install the timing cover and balancer to varify the timing mark is at 0° (you are varifying the TDC with the slit in the balancer vs. the timing marks on the timing cover)
so if its notat 0°,,,, then you know its off one tooth on the cam gear... Turn the crank to 0° pull the balancer and timing cover off, and check the gears to see if they are straight up. IF the 2 dots arent lined straight up pull the cam gear off and move the cam left or right to make it straight up.
Now that you have varified you are 100% TDC and the chain is not installed one tooth off, it will be a huge dog if it runs one tooth off...
So install the cam button and oil slinger and install the front cover WITH THE CAM SENSOR WITH SHAFT OUT OF THE TIMING COVER!!!!! :biggrin:
You are now ready to tighten the timing cover, and install the balancer to 219ft/lbs
Now ask me for the directions on how to correctly dial in the cam sensor
HTH
BW :smile:
HTH
BW :smile:
 So I ordered a new one.
  So I ordered a new one. I don't want to break anything.
 , but I've never done this and I'll only learn if I do it myself.)
 , but I've never done this and I'll only learn if I do it myself.) ) CCW 2 TEETH SHOULD BE FINE with the chain as it is,and they will line up, just check balancer to see if its at zero, then varify the marks are lined up,
