SignUp Now!When the last stock timing set I had disintegrated and slipped, at idle, it bent some valves when they crashed into the piston tops.Quick6'n'-K.C. said:Good advice above, but wait till it breaks before you tear it apart.
If it slips, it might bend pushrods if the heads have been decked.
Thats the worst horror story ive heard about if the nylon gear breaks.
BW
MeanBuicks said:When the last stock timing set I had disintegrated and slipped, at idle, it bent some valves when they crashed into the piston tops.![]()
Are these part #s for the all-metal gears??WHEEZER said:GM Timing Chain part#12537202. GM Bearing type cam button part # 25532588. In case your cam sprocket needs replacing part # 25523115, crank sprocket part # 25519954..
