call me stupid....so that paper thin gasket between the oil pump and filter housing. i used i very thin layer of gasket maker on either side of that. I just read somewhere that is kinda a no-no? i didn't pack it with Vaseline either. all i was going in there to do was replace that gasket. also it appeared to have some slight gouging on the filter housing where the oil pump gears are? im thinking i need to pull it back apart spend the 10 bucks and get another gasket? should i worry about the scoring of that filter housing?
oh and also the crank shaft gasket the parts store sold me is like kinda backwards looking compared to the factory one? has anybody else run into this problem?
