Tom Tom Turbo
Turbo Goes Woo Woo
- Jul 10, 2002
I bought a high volume front cover that has been giving me sealing issues from day one. I finally had it machined flat and they had to remove 4 thousandths from the sealing surface to make it flat all around. My question is, with 4 thousandths difference in distance from the inside of the front cover to the front of the cam, do I now need to re-shim my roller cam to set the endplay or is that a small enough change to be fine just putting it back together.
If it helps, I know we set endplay to whatever Comp suggested when we installed the cam. A quick reply would be great because I am planning on trying to put it back together this weekend.
Thanks in advance!
Thanks in advance!
