Brian, I definitely agree with you 100% that the only two front covers to consider are GMs' cover and the TA1530A Front Cover!
The TA cover just needs little to no work cleaning up vs the GM cover & you can pretty much just bolt it on & go.
But both are the best out there.
With my recently installed TA front cover and new Melling Oil Pump Gears my car gets 55psi oil pressure just cold cranking!
I now have 70psi at oil pressure at cold start up.....and during warm up it settles to 60psi.
Once the engine is up to full operating temperature and fully warmed up I have a solid 28psi oil pressure at idle.
As far as pricing goes, I was very fortunate as when I bought my TA front cover they had a promo going just before Christmas......I purchased the front cover, billet steel timing gears with timing chain, etc......believe I got 15% off list price, so in the end it was very little more than what a GM cover sells for.
dave
