hot air 84GN
- May 7, 2009
I'm a little confused. Which timing cover to purchase. I'm sure that you get what you pay for. And I'm sure that Earl's covers are "da bomb!" To start with a GM cover and then modify it, porting and smoothing everything up would probably be the best way to go. But what about all of those cars still running stock covers?? They were'nt modified, and still run great. I dont mind the extra work, but why do we NEED to drill and port all of those passageways? Is it truely necessary? Does it work OK if it IS just bolted on? I guess what I'm getting at is, I see covers sold at reputable vendors: TA Performance, Gbodyparts, Full Throttle. And if you can't get a GM cover anymore (hear they're discontinued) what place sells a good cover? I don't need anything excessive, just something that will work. DON'T want a P.O.S. either.
Also what about oil pumps while I'm looking at covers? I hear that a high volume pump isn't necessary...but better pressure is better right? Or not?
Any imput or opinions would be greatly appreciated!!
