Timing marks dont line up?
workingdan
Installing a roller cam and when installing the roll master timing chain, the dots dont line up. There is 2 dots on the lower gear and one on the upper. They look to be off about a tooth. Any idea what I am missing?
Also do I need to run the chain adjuster with the new DR timing chain?
Heres some pics
turn the crank a couple degrees clockwise and take another look
and no tensioner
And don't forget....no tensioner needed w/DR chain. Been there, done that, when the tensioner broke it caused a ton of expensive problems. :cool:
