Timing questions...
Cheez Wiz
I hear of chips with various degrees of timing. High, low, etc. The question I have is this: Is there a timing "curve" in the TR's? I.E., is there a such thing as "base" timing, then a progression to the maximum allowed by the chip? Or, does it always have maximum allowed then it backs off timing as warranted by the knock sensor and such? I guess what i'm trying to ask is there a correllation between the TR and a standard style (distributor) ignition?
Yes there is a "timing curve" but what everyone is refering to is the timing @ WOT. This would relate to the basic distributors baseline timing plus mechanical advance but not vacuum advance.
I am sure that others know more about this than I do, But if you have access to DirectScan, it will show you exactly what timing is being run at any time. (I get about 46-50deg at cruise, and 26 deg at WOT) and yes, the knock sensor tells the computer to pull away some of that timing if it senses detonation.
26 at WOT :eek: This is a race chip, right???? Sure hope so. Not even hot street chips run that high!
