You may need an impact wrench to remove the pulley from the front. Also be careful, when you split the case the brushes will pop out. There should be holes in the brush housings that you can put a piece of wire or paperclip through to hold the brushes in the retracted position for reassembly. The whole process is very simple...rebuilding alternators is easy.
