tire compound ??
If you want great traction you can't go wrong with the m/t drag radials, these tires hook like crazy. With 9lbs of boost off the line I have done my best sixty ft time(1.52) with these tires.The only bad thing about these tires, is that I heard they wear out very quickly. I can't tell you about how fast they wear because I just got them last year, but I Don't really care because when you drive on the street with these tires you feel as if you are unbeatable. They hook great and drive much better than a street slick(dot), and compared to a drag slick you are only limited to use them on a race track, but these drag radials you can drive them where ever you want.
86 Grand National t-top (59000km)
stock long block,stock suspension, red stripe convertor, te44, smc alk injection, 24lbs boost, 94 octane, hooker cat back with dyno max ultra flow muffers, tomco 30lbs injectors, dynotech stage 4 street chip, thdp, mease 24 row IC, MT drag radials (275/50/15) 3800lbs race weight.
best ET
60FT=1.52
1/8= 7.38
I/4= 11.74
MPH=113
BEST MPH= 114
