Tire size...Please advise
I am nearing completion of my GN make over and have elected to run the ROH drift R wheels. I ordered 18-9 front and 18-10 rear. As they come as a set for the GN. Tires: I ordered nitto 305-35-18 rear and 275-35-18 front. Anyone running this size / combo etc?
I want to ensure they will work before I mount tires as I am unsure how one can return to tire rack " already been mounted tires."
Thanks in advance.
Those are Huge!!..becareful...i run 295/40's in back (11 inches wide)an 255/40's in the front,Same wheels,Roh drift's,They come with billet wheel spacers,1 1/2 for back 1 inch in the front, i have swapped my suspenition out for aftermarket unit, so i don't have to use the spacer in the front becuase the disk brake an a-arms pushed out the 1"..watch the front size, the turnning an mainly fender lip clearances...i run falken anzensi's
hellobozos-albums-s-back-2-24-11-picture3286-roh-drift-wheels-1-inch-drop-custum-arms-all-around-aerospace-disk-brakes-600hp-stroker-stock-block.jpg
[/IMG]
Enjoy!
So you think the issue will be in the front when turning sharp?
I am also using the hotchiks complete front and rear system.
Hope it all goes together well.
