Squid4life
- Jul 5, 2004
A few questions now that my new Tlink is telling me my car is FUBAR.
I am getting the following malf codes:
32 EGR diag
34 MAF sensor low
41 Cam sensor failure
13 O2 open
22 TPS low
My readings are as follows:
IDLE:
TPS .76
O2v 379-461
Maf 9G/S
Xcounts 13-17
BLM 127
ESC 11 no matter what!
While driving (which I will not do again until this is fixed!) 3050 RPM
TPS 1.12
O2v 660
MAF 20
XCNT 6
ESC UP TO 68!!!!!!!!!!!
Obviously I have a sensor, or bunch of sensors bad or maladjusted, but where do you start? Obviously TPS setting is bad, but will one maladjusted sensor snowball and set off other codes/issues?
I have the following possible problems (or so it says in Tlink help)
EGR control solenoid
EGR valve
MAF sensor
Cam sensor
TPS
O2 sensor
What should I start with first? I already have a new O2 sensor to install, the TPS should just need to be reset, but have no idea how.
The cam sensor either needs to be adjusted or replaced, which is $216!!!
ARRGH!!! Someone please point me in the right direction so I don’t spend way too much money replacing everything. What should be the order of checks/adjustments/replacements?
Squid
32 EGR diag
34 MAF sensor low
13 O2 open
22 TPS low
IDLE:
TPS .76
O2v 379-461
Maf 9G/S
Xcounts 13-17
BLM 127
TPS 1.12
O2v 660
MAF 20
XCNT 6
EGR valve
MAF sensor
Cam sensor
TPS
O2 sensor
Squid
