Scott89TTA
- Jul 12, 2005
To girdle or not to girdle ?
I'm getting ready to start the mods listed in the bottom of my sig along with replacing a bad rear main seal. Also replacing the motormounts with HRParts-N-Stuff poly mounts. So while the oil pan is off would it be worth while to install an engine girdle? Looking at this one RJC Engine Girdle and will it work on the TTA, will there be enough clearance between the frame and the oil pan, more importantly will I be able to install it without pulling the motor? Will it be a worth while addition to a stock bottom end and add some additional security on a 47K motor getting a GT6776e turbo and the 25+ lbs of boost that goes with it? What do you guys think?
Thanks,
Scott
Thanks,
Scott
