Ok. I took the TTA for spin today for the first time with the scan tool hooked up. The car is stock except for a drag radials and a chip. The chip is borrowed from a friend that races an 11 sec. GN but swears the chip is a pump gas street chip. After letting the car get up to temp. I hit the gas and kept an eye on the boost and Knock retard. At about 10-11 pounds of boost the knock retard registered 8 deg..... I let out of it fast! I thought I read it wrong. So I tried it again. This time at about 12 pounds it registered 10 deg. wwwoww. I let off again. I am running 93 octane gas with JB octane boost. The car seems to run smooth and fast, but I'm affraid to crack into it because at such a low boost it's already way to much knock. I thought that knock was caused by to much boost. 12 pounds is not alot of boost. Am I missing something?
Please help. What could be causing this condition. Thanks.
