SignUp Now!You know I use to say if your having a bad day two things put a smile on your face. Kids and dogs. Now I am placing a third Toms video
! Great work Tom . The twinkie had me roltflmao.
Great videos Tom. Keep them coming!
Great video. Looks much better with the stock rims and drag radials. Beautiful car. Well done.
If your at the dyno, the best thing to do to avoid the kick down is to leave it in drive, not over drive to avoid the kick down and roll into it.
Great job
Thank you for the kind words Mike! I love your car. I agree about the stock wheels and will definitely be leaving them on. Thank you also for the dyno advice, I'll definitely try that if I go again. The dyno operators suggested disconnecting the TV cable, but that seemed way off base. I said "no, thanks" and called it a day.
Sounds like a good way to lose a trans! He probably thought the TV cable was a kick down cable. Older cars had vacuum operated TV set ups and the cable made it drop a gear. Your tv cable controls the pressures inside the trans at WOT.
Tom, you need to increase your driveshaft speed to keep it from kicking down. I think around 60-65 is about where you need it. Good dyno none the less!
Nice video and good time at the track. My only critic is mounting the Scanmaster in the glovebox. To me it's way too important to hide away and even if the door is left open it's a safety hazard to look at it for knock retard. I keep mine right in the line of sight.
Hey Tom, very very nice! Love your road test & drag footage. Too bad about the Dyno & V-box fail . That's what you get with an over-abundance of torque!Again well done my friend!
You have a good baseline, now crank the boost!
Thank you John, I'm glad you enjoyed it! Yeah, the dyno was a bummer as was the Vbox test. I've found now that the drag radials will hook on the street under most conditions if they are aired way down and are really hot. I would bet that wider ones would make a big difference!
