BLACK MAGIC RACING
formerly turbo_canuck
- Jul 18, 2001
Doing a massive cleanup, here's the big list:
86/87 PARTS:
-Stock crossover pipe-$ 35
-stock intercoolers (3) - $80 each
-turbo heat shields (2) - $30 each
-3.42 richmond gears - $90
-stock intercooler shrouds (3) - $25 each
-stock exhaust elbows (2) - $10 each
-stock inlet bells (2) - $5 each
-stock up pipe - $25
-stock wastegate actuator (3) $15 each
-turbo brackets (2) $15 each
-quarter panel extensions pair (non spoiler) - $20
-clear parking lenses - $15
-stock posi rear - $800
-stock turbo cores - $90 each
-stock front sway bar - $40
4 stock t-type wheels w/ caps - $275
front GN bumper - $100
pair gn lower door panels- $60
complete engine harness - $250
4 GN wheels w/ new caps- $300
2 85 gn wheels with broken center rings (good for slicks) - $100
stock gn valve covers - $60
stock dowmpipe (2) $20 each
stock fuel pressure regulators (3) $20 each
cut chrome turbo shield - $75
stock ECM - $75
a/c lines - $50
2 stock turbo cranks - $300 each
Blower motor- $50
Flexplates (2) - $35 ea.
Throttle body and plenum, no arm, spring or iac- $ 125
Cruise control unit- $ 40
EGR valve and solenoid- $ 50
Stock shifter- $ 30
Right side air dam- $ 25
PERFORMANCE PARTS:
March underdrive pulley kit w/intercooler fan- $120
Chrome moly stock length pushrods- $50
B+M line lock- new- $60
Pair of mint redone GTA rears- $ 225
New heated 02 sensor kit- $80
204/214 speed pro hyd. cam - $75
.030 speed pro forged pistons - $200
Pair of 8.5" vectors, centers painted black, holes drilled for screws- $175
Pair of 8.5" vectors, good shape, $250
Set of centerline auto drag high polished wheels, 2 15x7, 2 15x8.5 like new- $575
ls1 maf sensor - $85
Kirban variable rate rear springs- $60
red's double pumper w/ switch - $425, used for 2 months, track time only
4.10 richmond gears - $125
B+M torquemaster torque- 2800-3200 stall, th350,th400- $200
84/85 PARTS:
complete intake - $90
turbo/ throttle body assy. (core) - $80
engine accessory bracket - $25
braided down pipe - $20
INTERIOR:
Green Steering wheel- $80
grey dash pad - $$80
rear quarter window trim - $15 pr.
3rd brake light - $5 each
a-pillars for t-tops - $10
t-top wide front trim - $10
CAR AUDIO:
Alpine CDM-7861 flip face cd player- $150
Alpine CDA7863 flip face cd player- $ 190
MTX thunder4122 2 channel amp- $ 100
Memphis mono amp 16pr1kd- $ 250
Clarion 15"xw series sub in box- $250
FRESH LONGBLOCK ---4 RUNS:
10/10 stock turbo crank
billet center mains
RJC girdle
stock checked + magged rods w/ ARP bolts
.030 forged speed pro pistons, moly rings
comp cams 212-212 hydraulic roller cam + lifters, roller cam button
comp "beehive" springs, retainers, and locks
rollmaster timing set
comp hi-tec pushrods
hi-volume front cover
RJC head gasket kit
Fully race ported iron heads + port matched intake
manley severe duty stainless valves 1.77/1.50
t+d shaft mount roller rockers
cost me over $5000 u.s to build, sell for $4000, only 4 runs on it!!!
86/87 PARTS:
stock ECM - $75
a/c lines - $50
Blower motor- $50
Stock shifter- $ 30
PERFORMANCE PARTS:
84/85 PARTS:
INTERIOR:
CAR AUDIO:
billet center mains
RJC girdle
RJC head gasket kit
