Speed_Dreamin'
- Sep 30, 2005
Mods to my 87 GN:
9 in K&N
rebuilt TA49 (unconfirmed, just bought the car)
stretch intercooler
Dutweiller neck
RJC Power plate
3 in DP
Test Pipe
2.5 in cat back w/ turbo flows
Hotwired Walbro 340
Adj FPR
009 injectors
Hood Mount FP gauge
Scanmaster 2.0
Unknown chip
119K unrebuilt, otherwise stock engine
When I bought the car the Autometer boost gauge was reading 8 lbs max. Really had to get into it to see any boost, turbo would not spool, would not even spin the tires while attempting to brake torque. 3 turns on the waste gate rod, instant (comparitively) spool up to 10 lbs and the car smokes the tires with a brake torque. 3 more turns on the waste gate rod and the gauge still reads 10 lbs. Yes, I'm sure I was not just spinning the rod, but actually decreasing the length of the rod. The Y connector has the fork pointing towards the compressor housing. What are some things I could check?
Also, I noticed that there seems to be an actual mechanical stop internal to the turbine housing. If I swing the arm to the left stop and then back to the rightI can feel a stop, shake it around a bit and it will continue to move to the right and stops again - I cannot get it to move beyond this point. This 2nd stop happens to be right where my actuator rod is sitting right now, even if I wanted to further increase boost I'm not sure that I could. What's going on here?
9 in K&N
stretch intercooler
Dutweiller neck
RJC Power plate
3 in DP
Test Pipe
Hotwired Walbro 340
Adj FPR
009 injectors
Hood Mount FP gauge
Scanmaster 2.0
Unknown chip
