SignUp Now!Originally posted by fly89gta
Also will they bolt up to a 700-r4?(i assume they would)
Originally posted by MeanBuicks
Only if the 700-R4 in question is an '82-'84 1/2. All 700-R4s (& 4L60E) subsequent to that received a larger diameter input shaft with a different spline count than the 200.
Originally posted by GNVAIR
You could use a driveshaft from an 82-up F body with either a T-5 or a TH200 as most of the 82-83 V8 models had. Its the same length as the TH2004r and uses the correct yoke
Ok, if I remember correctly from my tranny swapping days.....
the following transmissions will use the same lenth drive shaft when used in the same type of vehicle
