V6-Sauce
- Aug 23, 2008
The bolts on top of plenum to manifold. I know the 3 regular looking bolts are M8-1.25-25mm(factory). Does someone know the size of the 2 back side stud bolt. The ones that hold the brackets on each side.
Also I have another question, I'm using the RJC power plate with a plenum gasket top and bottom. Because of the space of the plate just so the bolt snugs down I went with M8-1.25-30mm instead of the (factory M8-1.25-25mm). Is that enough, to snug the bolt down for a good seal. I'm thinking doing the same for the 2 stud bolts at the back too. Go maybe 5mm longer than stock? The back two stud bolts weren't catching very well. Thats a vacuum leak
