Torque for steel cap
Boostdeznuts
TURBO PART WHORE
How many pound is needed for steel caps and in what sequence . I cant seem to find it in GNTTYPE.ORG
TIA
Lenny
The torque numbers are usually about the fastener, not the cap material. So, what fasteners are you using?
I would go with specs. from ARP on stud and regular manual sequence.Thats what
I did on last build.
same for steel as for cast. go with the arp torque values 100ish
Torque Specifications for 1986/87 Turbo Regals
Chris Fasulo
Torque Values
***** All Specs are for clean and lightly-lubricated threads only ********* Description Ft-Lbs N-M
Spark Plugs 20 28
Main Bearing caps to block 100 135
Balancer Bolt to Crank (min) 219 297
Connecting Rod Bolts 40 54
Sepentine Belt Pulley to Balancer 25 33
Flywheel To Crank 60 81
Oil Pan Drain Plug 30 41
Oil Pump Pressure Regulator Retainer 35 48
Oil Gallery Plugs 25 34
Oil Pressure Switch to Cylinder Block 24 32
Oil Filter Assembly to Pump Cover (center bolt) 18 24
Timing Chain Cover to Block 22 30
Water Pump Pulley 21 29
Thermostat Bolt to Intake 13 18
Intake Manifold to Head (in proper sequence), see below 32 44
Exhaust Header to Head 37 50
Engine Mount to Block 59 80
Timing Chain Sprocket 31 42
Rocker Arm Shaft to Head 25 35
Accessory Bracket to Head 37 50
Alternator Mounting Bracket Through Alternator to Head at Pivot Location 44 60
Starter To Block 35 48
Cam Sensor Hold-Down Clamp 20 27
Transmission to Block 35 48
Bolt-Special Movable Timing Chain Dampener 14 19
Knock Sensor to Block 14 19
Fuel pump block off to Timing Cover 22 30
Turbocharger Inlet Adapter to Turbocharger 17 23
Turbocharger oil drain pipe to Turbocharger Center Housing 22 30
Turbocharger Compressor Housing to Center Housing 13 17
Turbocharger Turbine Housing to Center Housing 15 20
Exhaust Manifold to Turbine Housing 20 27
Power Steering Pump to Accessory Bracket 20 27
Turbocharger Mounting Bracket to Head 37 50
Turbocharger and Elbow Heat Shields to Mounting Bracket 20 27
Turbocharger to Mounting bracket 20 27
Throttle Body to Intake Manifold 20 27
Front Vacuum Line Bracket to Intake Manifold 20 27
Engine mount to frame mount 48 65
Engine frame mount to frame 33 45
Air Conditioning Compressor to accessory bracket 37 50
Power Steering Pump to accessory bracket 20 27
Shifter cable bracket to transmission 20 27
Flywheel to torque converter 46 63
Transmission mount to transmission 25 34
Transmission mount to frame 40 55
U-joint strap at rear axle 16 22
My understanding is you use the torque spec that was used when the caps were fitted to the block. Most shops stamp the torque spec into the pan rail or tell you on the build sheet. Look around the block or contact the builder. If both of those turn out to be of no use, then work with ARP, and learn to measure and determine clearances for an educated guess.
