Apr 18, 2014 #1 R Renthorin Lone Wolf Joined May 24, 2001 Messages 3,024 Anyone know the TQ for the rear diff bolts? I was told 30ftlbs by a GM guy but want to clarify from a TR owner.
Apr 18, 2014 #2 E earlbrown runs with scissors Joined May 26, 2001 Messages 7,539 Probably more like 30 inch pounds. But I never torque those bolts (or use a gasket). 3/8th ratchet and a short extention... turn 'em down until they're 'tight'.
Apr 18, 2014 #3 jpwalt1987 Well-Known Member Joined Nov 9, 2003 Messages 1,885 Are you talking about the cover bolts or the bearing cap bolts that hold the carrier in? Posted from the TurboBuick.Com mobile app
Apr 19, 2014 #4 N novaderrik Well-Known Member Joined May 12, 2004 Messages 8,076 those are 5/16" bolts- anything more than about 20 ft lbs or so is begging them to break... just snug them down with a short handled 3/8" ratchet... if they leak, snug them a little more..
Apr 19, 2014 #5 F Fast4Ward Well-Known Member Joined Mar 27, 2005 Messages 1,162 per Earl ....done same 5x now ....been in her rear more than I like
Apr 19, 2014 #6 R Renthorin Lone Wolf Joined May 24, 2001 Messages 3,024 Ok cool. I'll just snug them down lightly.
Apr 20, 2014 #7 R Renthorin Lone Wolf Joined May 24, 2001 Messages 3,024 Drained the old fluid, cleaned things up, put on new cover (replacing TA Performance cover), and added 2 quarts of oil plus anti-chatter. No leaks and the grinding on sharp left turns is now gone
Apr 20, 2014 #8 GNONYX Well-Known Member Joined Oct 16, 2009 Messages 1,754 Just in case you need more info on bolts Torque Attachments TurboBuicks.com_Torque_Spec.pdf TurboBuicks.com_Torque_Spec.pdf 299 KB · Views: 1,012
