So I'm finally putting my engine back together and just wondering if anyone knows the torque sequence for the Mains or if there is even a sequence. Also have ARP studs and was told 100 ft/lbs correct me if I'm wrong please.
25/50/75/100. Does not matter which caps are done in order. Are they new studs, if so I would repeat the process two times to stretch cycle the studs. Also was the block align honed and what lube are you using?
