it's just a six
- Dec 27, 2005
Not sure if this has been posted before.
Just wondering about the total timing used for each gear.
I know there are a lot of variables,but from what I read here ,it seems most guys pull timing out only when going into 3rd gear or higher?
Guys w/there Syclones & Typhoons do not seem to pull out timing in the taller gears.
How many degrees do you guys pull out on a typicle street GN running pump gas & methanol inj?
Also the typical total timing in each gear.Say running 20-25 psi boost.
Thanks.
Thanks.
